820-2733-A only LED 1 & 2 on. Fan on. No Chime and no USB
protocold
Without ram, the iMac will beep. Put the known good ram in, it will turn on with only LED1&2 and Fan. No Chime. No USB.
Where should I start looking?
To be sure, you get steady LED500/10?
Do you get 12V_S0?
Remove the CMOS cell in the process repair.
This will force the board to turn on automatically, when power is applied.
protocold
thank you.
problem resolved, turns out wrong CPU from 2010 (i3-550) was installed on this late 2009 board (same socket but not compatible)
