820-2850 Battery not detected.
Dewanbd
Turn on with charger, green light , in osx shows no battery, but if i take out power adapter the laptop works
fine with battery. This is know good battery, Battery indicator no light. Any help please.
Dewanbd
Yes , same with bill disconnected.
Voltagae and SCL= 1v, SDA= .5v TO 0V
diode mode to ground at SCL=.34, SDA=.463
You have big difference on SCL/SDA lines in diode mode.
Could be U7000, or SMC.
Remove first C6952/53 (if present) and check again.
Dewanbd
After removing c6952/53 got scl=.323 and sdl= .454, Changed isl625, scl=.454, sdl=.454 but voltage at sdl =0 , scl=3.42. it could be smc??
If both lines have now the same diode mode reading, this is a progress.
Be sure R5280 is good snd check continuity to SDA line.
Dewanbd
R5280 is good 2k and continuity to sda line is ok, Pin 10 at u7000 =0 v. it could be u7000 itself faulty or smc?
