820-2850 TB3T Sensor is faulty in ASD
arash
Hi guys, the machine doesn't recognize the battery and partially working with the charger connected - shut down sometimes. I cannot located the TB3T sensor on the schematics and brd file.
Can someone please direct me to its location? Thanks
It's the battery sensor. Tried a known good battery? Disconnected battery indicator? After that it could be bad ISL or SMC, probably SMC.
arash
Tried with a good known battery, with/with out battery indicator connected shows the same error.
Also, PPBUS_G3H seems to me at fault --- PPBUS_G3H=9.9V with battery and charger connected. PPBUS_G3H=8.8V with only charger connected
8.8V with just charger would at least indicate an issue with the 6259. Replace it and check the sense resistor circuits.
arash
U7000 was replaced. Current sense resistors circuits seem to be OK. The voltage remain the same as before - 8.8V and 9.9V. The problem persists
arash
I've rechecked the surface for bad soldering and soldered the chip again, same results as before. Any other directions I should look into?
