820-2879 reboot and black screen
MDY
This board works ok but each 5-10 minutes reboot and blackscreen. Could be bad MCP?
Board has no liquid damage.
Check if the piece of tape is still on the airport connector that prevents the metal sponge from shorting out the pins. Could also be a bad RAM slot. If that does not solve it I call it trash.
MDY
Sorry but cannot understand you. Some picture you can share from internet what you mean?
aprendiz
Moderator
Here the connector with tape and the sponge in cable.. Next to the red box...
MDY
So, if I disconnect this cable should be enoght, right?
Sorry, but I am not sure if I understand correctly.
