820-2915 no power
MDY
Magsafe ok
PPBUS – 12.56V
3.42V present
SMC_RESET_L - 3.3V
SMC_ADAPTER_EN - 3.3V
PP3V3_S5 - 3.3V
32khz for PCH present
PM_PWRBTN_L - 3V
PM_RSMRST_L - 3V
PM_SLP_S5_L -0V
PM_SLP_S3_L -0V
PM_SLP_S4_L -0V
PP5V_S4 -0V
Any idea what to do next?
Board is pretty clean and no liquid damage.
MDY
R1800-R1803 voltage on both pins: 3.3V ALL
PPVRTC_G3H (V RTC) - 3.3V
RTC_RESET_L (Reset RTC) - 3.3V
MDY
Board power with 5V_S3 present one time and only cpu core was missing. But when I reconect the board it will not power anymore.
Now it is again as before. This mean no short there?
PCH bad?
MDY
When I short PM_PWRBTN_L to ground, I can see a pulse at PM_SLP_S5_L
This mean PCH respond, right? Could be bad PCH? Customer told me wasnot dropped.
MDY
Yes it charge the battery. Will not power on from battery. But I just put on the fan and realized that fan speed always for 1,2 seg.
I also noted that on coil 3V_S5 to ground is only 100ohm. Have a board to compare? Anyway I do have 3V_S5 present.
MDY
fan spins - this is new for me. I dont know what happned. Now I also have pulse 0-5-0V at PP5V_S4
Nothing in R2584 ALL_SYS_PWRGD
PP1V05_S0 - appear for 0.5 seg
MDY
Cannot find missing voltage.
Only suspect I have is L7720
It is PP1V5_S0
It goes only to 0.25V when I plug ac adapter.
To ground is 146ohm
Diode mode: 0.310 and 0.222
SOmebody have 2915 board to compare?
Since when is L7720 1V5? Pretty sure it is 1V8. 146 Ohm to GND should not be a problem, so dead U7720 is possible. I assume you checked enable is present.
