820-2936-B One USB port not working
Cire3
820-2936-B One USB port not working , was two but after a ultrasonic cleaning one has been regained. No signs of liquid damage, but had some crusty spots on the board, Both USB had 5V at the connection however would not read data.
After it's bath, one USB (Closest to the user) started working. But the rear one did not change.
Any direction I sould be going ?
Cire3
Ok, working with connector J4610 (USB that has power but no data)
J4610
Grounds on pins 4,5,6,7,8 are good.
Pin 1 @ 5V
Pin 2 is connected to L4610 Pin 3 & Pins 5 & 2 on D4610
Pin 3 is connected to Pins 3-4 on D4610 & Pin 2 of L4610
L4615 @ 0.2 Ohms
L4610 Pins 1 & 2 OPEN
L4610 Pins 3 & 4 @ Jumping 40-80 Ohms
Same coil on J4600 pins 1&2 3&4 Ohm @ 1.6
I can assume I need to replace L4610 ?
And where would I find these coils to purchase?
Thanks in advance !
You can connect corresponding pads directly.
Use very tiny enameled wire, like 0.03-0.05mm.
Be sure no short on any pad before...
JohnB8812
Start by replacing L4600/5/10/15. Sometimes those filters fail for no reason and will cause one port to not work.
Cire3
Any way to find what other boards are compatible for parts ? Cheat sheet somewhere ? Sorry, lots of questions....lol
"Use very tiny enameled wire, like 0.03-0.05mm."
You can use even 0.1mm wire.
Why insist so much to get original coils?
These are not critical...
