820 2936 dead
Any pulse at least at PM_SLP_S4_L?
Trigger SMC_ONOFF_L and check again.
Do you get 3V3_S5 and 3V3_SUS?
Also check SMC_ADAPTER_EN and PM_BATLOW_L.
EJS
SMC_ADAPTER_EN 3.45v
PM_BATLOW_L 0v
3V3_S5 3.32v
3v3 SUS 0v
No pulse on PM_SLP_S4_L, at least none that my multi meter could pick up. Toggled SMC ON/OFF, no change.
EJS
Yes, 0v PM BATLOW L measurement taken from pin 2 @ Q5040. I am using an OEM Apple 85w Magsafe 1
PCH will not start power on sequence untill PM_BATLOW_L goes high.
Any history available?
You may need to replace SMC, or reflow it at least.
Check S5_PWRGD signal, as PM_DSW_PWRGD and PCH_DSWVRMEN too.
EJS
No real history machine just stopped powering on as far as I know. The board looks like its in good shap, no LD.
S5_PWRGD 0v
PM_DSW_PWRGD 3.470v
PCH_DSWVRMEN 3.201v
EJS
Sorry 2info, I did not notice that, when I searched S5 PWRGD on boardveiwer it highlighted that line as well. So I have 3.45v on S5_PWRGD.
EJS
SYSCLK CLK32K RTC .383v
RTC RESET L 3.31v
PHC SRTCRST L 3.31v
PCH INTRUDER L 3.03v
PCH INTVRMEN L 3.21v
Check SMC_BATLOW_L.
If high, then should be PCH issue, pulling down PM_BATLOW_L.
In such case use good flux and heat PCH.
You may have luck and is only some crap under...
If you are sure about original Apple 60/85W charger, then could be SMC issue.
You can try to reflow it; change it if no result...
EJS
Im positive this is a 100% working OEM Apple charger, I bought it straight from the Apple store. I replaced the SMC, no change.
Try to start in SMC bypass mode, just in case.
Also try to start with battery and charger, both connected?
Not normal, but is possible that PCH blocks the SMC and this keeps SMC_BATLOW_L low.
Can you confirm with o-scope 32KHz square wave output from U2800?
Frequency meter is also good enough.
