820-2936 no backlight
Kyle93
Had mild water damage. Replaced U9701 twice and U9000
U9000 pin 2 and 3 3.3V pin 1 0V
r9731V 0V
what to check next?
Any voltage at pins 2, 3, 4 of J9000?
You don't get image, why looking for backlight???
Check if board has USB activity.
Do you hear chime at least?
JohnB8812
No chime and USB activity points to a whole different issue. Could be a BIOS issue in this case. Try a new one for testing and keep the old one in case it is the actual issue.
Kyle93
SMC bypass mode made no difference, just fast fan spin but still nothing on the screen.
liquid spill was only in lcd area
When board properly boots, you should note a drop from 1.1V to aprox 0.8V for CPU VCORE.
LVDS lines go from J9000 to PCH, which could got affected by liquid spill...
Kyle93
reballed SMC and no result.
Also changed SMC and still no result. After a few seconds i get one blink from white led every few seconds. Makes no difference if ram is inserted or not.
VCORE still steady 1.1V
Kyle93
replaced r7402 and now have chime but still no backlight.
J9000 3.2v pins 2, 3, 4.
Already replaced u9701
