820-2936 sometimes green light no power
lincev
hello I need help with this board, no antecedent damages, only sometimes green light no fan spin
neither turn on with smc bypass mode
some values:
ppbus is 1.0v
pp3v42 is 3.3v
lincev
ok sorry
C7040= 1v
U7000
Pin1=0,35v
Pin2=0v
Pin3=0v
Pin9=0v
Pin12=0v
Pin13=0v
Pin14=0v
Pin15=0v
Pin17=0,53v
Pin19=0v
Pin20=0v
Pin27=1,3v
R - Pin17/18= 0,32ohms
R - Pin27/28= 20,1ohms
"Pin2=0v"
No need to check anything else then; fix that problem!
Start checking diode mode to ground there.
Bad R/D7005?
lincev
nice my problem is with D7005
now I have Pin2=16,5v but don't turn on and don't have led green
now I detect continuity in pin 21 and Q7035, maybe I could have reballed the U7000 wrong and this pin21 is playing dough?
lincev
C7040= 1v
U7000
Pin1=15,5v
Pin2=16,5v
Pin3=3,95v
Pin9=0v
Pin12=3,44v
Pin13=3,4v
Pin14=0v
Pin15=0,03v
Pin17=0,58v
Pin19=5v
Pin20=5v(but count down to 0v)
Pin27=15v(but count down to 0v)
R - Pin17/18= 0,28ohms
lincev
im replace Q7030/35 of other board with problem gpu
check C7025 value 556 and R7025 I check with 2 boards (once is work) 0,01 value scale ohms 200 and check for example R7022= 09,9
F7040 out a pin1 0.9v
"check C7025 value 556"
If you don't know how to check capacitor, replace it.
Be sure to get good solders...
lincev
hi again, I replace C7025 but continuous with 1v at F7040 Maybe it doesn't replace Q7030735 correctly?
U7000
Pin1=15,5v
Pin2=15,9v
Pin3=0v
Pin9=0v
Pin12=3,44v
Pin13=3,4v
Pin14=0v
Pin15=0,03v
Pin17=0,58v
Pin19=5v
Pin20=5v (pero cuenta atrás hasta 0v)
Pin27=15v (pero cuenta atrás hasta 0v)
lincev
ok i have shot in R7011 and C7011(remove two items)
R7010 is good value 29,3 (scale 200k ohms)
now I have 0,67v in pin3 without fuse, R7011 and C7011
lincev
ok R7011 and C7011 soldered ! no short
change U7000
U7000
Pin1 CHGR_AGATE=15,5v
Pin2 CHGR_DCIN=15,9v
Pin3 CHGR_ACIN=0v
Pin9 CHGR_AMON=0v
Pin12 PP3V42_G3H=3,44v
Pin13 CHGR_RST_L=3,4v
Pin14 SMC_BC_ACOCK=0v
Pin15 CHGR_BMON=0,03v
Pin17 CHGR_CSO_N=0,58v
Pin19 PP5V1_CHGR_VDD=5v
Pin20 PP5V1_CHGR_VDDP=5v (now permanent)
Pin27 CHGR_CSI_N=0v (now 0v)
lincev
R7010= 29,5 ohm scale 200k is good im compare with other board..
maybe this U7000 is bad too... I try with other IC
Edit: sorry I try again and now I have 0,64v... CHGR_ACIN
