820-3023 3 beeps no PPVCORE_S0_AXG_R
rzeszu
Hi
I have this board for repair.
I checked power rails and:
only PPVCORE_S0_AXG_R this is 0V
ALL_SYS_PWRGD present
Still dead, fan spinning, and made 3 beep only.
I stuck with that.
Kindly Regards Mariusz
AXG not present is normal.
1.5V present at L7330? If yes then this is going to suck. Inspect for liquid near RAM and CPU.
rzeszu
Ok, 1.5V present
I see some components are cleaned after liquid.
I forgot about one thing.
I replace u7400 and its starts but stop working after 5 minutes.
I thought that if CPUIMVP_AXG_PGOOD from U7400 is 0, and i change u7400
You wrote that AXG is not present is normal, please tell me when i should get it?
rzeszu
I have good working board for test for now. I put it to test other parts in this computer and now have same problem - 3 beeps WTF?
Is it possible that fault caused by display?
rzeszu
Ok i could understand it with first board which has some corrosion but what with KGB which is use for tests and now have same problem?
I don't know what you did.... 3 Beeps is something with the RAM. ESD damage, slipped screw driver, corrosion, bad luck. I just know that 3 beep boards when L7330 has 1.5V are a nightmare.
rzeszu
Ok i will reball all chips just for fun or sport or ...
And close this repair
Thanks for help.
Regards Mariusz
