820-3115-B Blown fuse, Replaced fuse and Display assembly and no backlight. Suspect U9701?
joshAU
Hi.
Macbook came in originally with no backlight.
Confirmed display worked - with torch from behind could see login screen.
Replaced backlight, which blew again.
Tried with known good display assembly after replacing fuse - unit worked.
Returned to customer.
Now, customer returned it with the same issue.
The fan goes to maximum and stays there after a few seconds.
Replaced backlight fuse - still no backlight.
Tried with another known working display assembly - same.
Checked voltage at PPVOUT_SW_LCDBKLT: ONLY 12.46v
Which makes me suspect U9701.
Checked inputs to U9701:
PP5V_S0_BLK: 5v
PPBUS_SW_BKL:12.6v
PP3V3_S0_BKL_VDDIO:3.3v
LCD_BKLT_PWM:2.63v (measured at pin2-r9704).
This last one is suspicious:
PPBUS_SW_LCDBKLT_PWR:12.6v (measured at pin1-R9731)
BUT pin2-R9731 measures 0.05v!
The resistance across R9731 reads 280K ohm.
However across R9715 showed only around 100 ohm, not the 100K it should.
I desoldered R9715, and measured the two points under it and I get the same 100 ohm.
Pin2 on R9715 shows 100 ohms to ground.
Given there is only 0.05v going to BKL_EN (A3 on U9701) measured from pin2 on either R9731 or R9715, does this mean that U9701 is internally shorted?
By the way, SMC_LID is 3.42v.
I do not have any spare U9701, so I removed one from another unknown faulty same logic board.
Afterwards, all the voltages are the same, and the same symptoms, although I cannot rule out that the board I took it from had the same issue.
Any suggestions on what I may have missed, or what to test next.
Any help greatly appreciated.
joshAU
Thanks 2informaticos.
Sorry, I'm still learning as I go.
I did checks to provide more information in my question.
Yes, that makes sense to have checked it with U9701 removed...hmm, yes, I should have thought of that.
I'll take off U9701 and checkBKL_EN to ground in diode mode and report back.
Thanks again.
joshAU
With U9701 removed, pad 3 (A3)(BKL_EN) shows, in diode mode, to not be connected to ground, and is connected to pin2-R9731 and pin2-R9715.
Any other checks I should do while the chip is removed?
The only pads connected to ground are the ones that are meant to be connected to ground, i.e. A1, A2, B5, and E4.
BKL_VSYNC_R (pad D2) and BKL_FLTR (Pad C2) both look correct at 10K ohms to ground, as does BKL_FSET (Pad B4) at 16.2K Ohms.
