ViBe
MacBook 820-3115-B with prior repair came in for battery not charging. MagSafe takes a few seconds after power-on to light green, never changes to amber, and intermittently turns off altogether.
PPBUS_G3H is a steady 12.29V with no battery attached.
U7000 was replaced. No change.
U7000 resistance on pins 17/18 is 3.2 Ohms and pins 27/28 is 20 Ohms.
R7005 resistance is 20 Ohms.
Steady CHGR_ACOK signal, even when MagSafe is not lit.
Q7030/35 both replaced. No change.
R5280 and R5281 resistance both measure 2 kOhms.
On SMC_DCIN_VSENSE; R5498 resistance 27.3 kOhms, R5499 is 5.49 kOhms.
On SMC_PBUS_VSENSE; R5488 resistance 23.3 kOhms, R5489 is 5.47 kOhms. C5489 not shorted.
Any help would be greatly appreciated.
*Update: Booted the machine and appears that it doesn't see the battery. R7051 measures 2.5 Ohms, R7052 is 0.4 Ohms.
