820-3115 green light OK, no boot, no chime
Cocobill
Hello!
got this board that worked fine yesterday and now appears dead. I've got green light in the charger, PPBUS_G3H is 12.54V, all main s5 rails are good. I did a visual inspection, no liquid damage but caps C1680, C1681, C1682 and C1683 did not look right, as if the metal part on each side was detaching from the body. I measured all four in beep mode and they are all short circuited!
Should I replace the capacitors and go from there or is the CPU blown and it’s a waste of time?
Cocobill
I have no oscilloscope, when measuring with FLUKE on voltage mode I get no reaction when connecting the power
Multimeter may be to slow to catch the pulse so this proves nothing. Check SLP_S4_L for pulse. Did you check all rails for short to GND?
Cocobill
Went to a friend who has a professional oscilloscope, measured on L7260, no pulse :( Is the board dead?
Cocobill
s5_pwrgd on chip U7941 pin 8 is 3.459V. R1800 pin 1 3.305V pin 2 3.209V, R1801 pin 1 3.305V pin 2 3.030V, R1802 pin 1 3.305V pin2 3.299V
Cocobill
Resistance to GND on L7260 pin1 1.047V, pin2 0.447V, R1803 pin1 3.304V pin 2 3.298, SMC_ADPAPTER_EN on Q7920 pin 2 is 3.439V
Repairable
typo i gues?
no charger/battery when measuring resistance.
Cocobill
Measured again although I did not have the board connected to power source. L7260 pin 1 .446 pin 2 .446. I operate with a FLUKE 17B+ and in diode mode there is a small V next to the reading, that's why I wrote 1.047V before, sorry.
Cocobill
Resistance to GND on L7260 pin1 .0446, pin2 0.447, R1803 pin1 3.304V pin 2 3.298, SMC_ADPAPTER_EN on Q7920 pin 2 is 3.439V
