820-3115 - No trackpad
kronos23
Working on a 820-3115 with no trackpad. Found that PP18V5_Z2 is missing on the connector, confirmed PP3V3_S4_TPAD is present. Traced it to U5805 and found the following readings.
1 - 0.053
2 - 5.07
3 - 0.000
4 - 0.185
5 - 0.001
6 - 0.000
7 - 0.000
8 - 0.037
So I replaced it but having the same results. Any ideas ?
aprendiz
Moderator
PP5V_S5_CUMULUS is present???' If yes, try another trackpad..... Z2_BOOST_EN should be high but it wont if trackpad is not detected...
kronos23
On L5800 I have 5V on pin 1 but nothing on pin 2 Based on schematics and board view I should have a filter there however these just look like test points ? Im confused.
aprendiz
Moderator
Sorry my mistake, schematic says pin 18 not connected for Z2 Flex, try another trackpad and flex cable.........
I'd first try a known good trackpad+cable. After that you need to check all connections from the connector to U5701, could be corroded trace.
