820-3115 not recognizing screen
Chuck60
Hi I was working on a water damaged board and I relplaced a few items on 5v/3v rail. It chimes now and I have CPU activity mouse flashing. but no display I’m missing J9000 ( pin 3 0v, pin 4 3.3v) LCD_PWR_EN 0v at U9000 and SMC_LID is 3.4v L9080, r9008, r9009, L9004 all measure good so I’m guessing the lcd isn’t being “seen” I’m using a b133ew07 test screen and a “new” screen cable. if I remember the screen is from a 2010 MacBook Pro so I’m guessing this set up should work if I’m wrong let me know.
Test voltage at LVDS_DDC_CLK/DATA lines.
Check if both R9008/9 are good.
Be sure to test with compatible screen.
Chuck60
J9000 pins
1- gnd
2-.582
3-.582
4-.339
5-OL
6-.610
7-.560
8-.600
9-.627
10-gnd
11-gnd
12-.628
13-.gnd
14-gnd
15-.605
16-.gnd
17-gnd
18-.606
19-.gnd
20-gnd
21-.577
22-.577
23-.577
24-.615
25-.615
26-.585
27-.585
28-.585
29-.585
30-OL
LCD unplugged voltages
Pins 2& 3 0v
Pins 6&7 0v
Pins 17&18 0v
Pins 20&21 3.5v
Lcd plugged in :
Pins 2& 3 3.3v
Pins 6&7 3.3v
Pins 17&18 0v
Pins 20&21 27.99v
"I have backlight now but no image LVDS_DDC_CLK/DATA= 0v all"
And what this mean???
Looks like you have backlight.
Chuck60
I’m not sure of what you’re saying.
I have backlight the screen is dim.
Apple logo on back of screen is glowing but no image or Apple/ flashing folder.
You asked me to check LVDS_DDC_CLK/DATA I checked and it had 0v. I thought I was having no image
J9000 pins 24-29
LED_RETURN_1 =.681v
LED_RETURN_2 =.682v
LED_RETURN_3 =.681v
LED_RETURN_4 .=681v
LED_RETURN_5 =.683v
LED_RETURN_6 =.824v
Chuck60
Ok I’ll first try with just the Lvds cable with no screen connected. I will try the screen on another dead board for measurement sake if I get 95ohms then I know for sure it’s the assembly. I’m thinking more like it’s the lvds connector :/
Chuck60
ok I fixed the dead board and this screen does indeed work. So what can it be ? Bad PCH ? LVDS connector?
Maybe I should Have startEd with what I worked on. Maybe I messed something up I repaired u6100, u7760, u7780, Q3380, f9700. I got these for $5 each so they where missing parts and or badly damaged If you would like pictures of these areas I can send some
Thank you for your help you have taught me a lot and I appreciate your help. I understand how frustrating it must be talking with a novice
Post voltage and diode mode on pins 2/3, 4, 6, 7, 17, 18, 21/22, with LCD connected.
Do you still get 95 ohms there?
Chuck60
——--Diode. Voltage
Pin 2 .462. 3.3v
Pin 3 .462. 3.3v
Pin 4 .333. 3.28v
Pin 6 .525. 3.28v
Pin 7 .561. 3.28v
Pin 17 .363. 0v
Pin 18 .351 0v
Pin 21 .570. 26.98v
Pin 22 .570. 26.98v
Pin 22 .570. 26.98v
still 95ohms
Chuck60
Ok I’ll checked it again. but my working board also had 95ohms. When I connect the screen :/ I powered it up the screen works and powered it down removed from power and test 17/18 it’s still 95ohms.
I understand 2/3, 21/21 pins are connected but I just check it and post The values separately. Redundancy is my life’s work :)
