820-3115 Power Issues
hambook
Hi all, I have an 820-3115 that is having issues. Came in with no liquid damage, customer reported they were watching a movie and it shut off unexpectedly. I get intermittent green light but it only pulls 0.013A from the bench PSU. Found that PP5V_S3 was shorted to ground (0.30ohm) and injected 1v, found C6213 to heat up so I removed it. Short is clear now but still not getting PP5V_S3.
PPBUS_G3H: 12.6v
PP3V3_SUS: 0v
SMC_ADAPTER_EN: 0v
PM_DSW_PWRGD: 0v
PCH_DSWVRMEN: 3.3v
PM_BATLOW_L: 0v
PCH_SRTCRST_L: 3.4v
PPVRTC_G3H: 3.4v
RTC_RESET_L: 3.4v
Then change U7200.
Be sure to have good solders and traces.
Also check diode mode to ground at L7220/60.
hambook
Changed U7200, double checked all the solders/traces. Am now getting
VREF: 679
VREG3: 637
VREG5: 503
L7260 seems really low, diode is 144, L7220 is 390. Does this mean something is pulling PP5V_S3 down?
hambook
Whoops, sorry. Completely forgot to check again.
U7200
3: 2v
6: 0.757v
8: 3.3v
13: 3.3v
16: 12.6v
17: 5v
So PP5V_S5 has returned.
hambook
Just to check my understanding so far. U7200 needs Pin 6 to be low, Pin 13 to be high, and 13/17 to be at 3.3v and 5v. So this chip is now functioning correctly?
"U7200 needs Pin 6 to be low"
Don't make wrong assumptions so easy!
However, 0.757V is the correct voltage there; theoretical value is 10uAx78.7Kohm=0.787V.
Chip's datasheet explains why.
You should now have 3V3_S5 present at L7220.
hambook
I do now have 3V3_S5 present at L7220. I don't have PP5V_S3 though. PM_SLP_S4_L is 0v. C1802/1803 are 3.3v
hambook
Update: After reading some forum posts, I replaced U2600 on a hunch. I now get consistent green light.
PP5V_S3: 3.3V
PM_SLP_S4_L: 3.3V
Power supply is drawing 0.226A. No fan spin.
hambook
Q7950
1: 0.033V
5: 1.075V
6: 3.29V
7: 1.505V
Also noticing now that the PCH gets hot after sitting plugged in for 5 or so mins. I take it that's not good...
