820-3115 pp5v_s3 short
Kyle93
Board is in perfect condition. No drop or liquid damage. PP5V_S3 is shorted at 0.47. When injecting voltage the only component that gets hot is L7260. Removed but short is still there.
What should be checked next?
"PP5V_S3 is shorted at 0.47"
Do you mean diode mode, or ohm scale?
0.47 in ohm scale is short for sure.
0.47 in diode mode is around 1 kohm...
Please post accurate information.
Do you get 3V3_S5/SUS and 5V_S5?
"yes, diode mode"
Why did you assume is short then???
Post exact PPBUS_G3H, SMC_RESET_L, SMC_PM_G2_EN (voltages).
Do you get 3V42_G3H?
Kyle93
On a working board the measurement was 0.318
PPBUS_G3H 12.60v
SMC_RESET_L 3.42v
SMC_PM_G2_EN 3.42V
Yes 3V42_G3H 3.42V
0.318 is lower, how could 0.47(0) be short???
Post U7200 voltages; pins 16, 3, 13, 8, 17, 1, 6.
Also post diode mode readings at L7220/60.
Kyle93
u7200
pin 16 12.60V
pin 3 0.015V
pin 13 3.4V
pin 8 0.03 V
pin 17 0.015V
pin 1 0v
pin 6 0v
L7220 0.129
L7260 0.025
Kyle93
u7200 changed
pin 16 12.60V
pin 3 2.009V
pin 13 3.4V
pin 8 03.3 V
pin 17 4.97V
pin 1 0v
pin 6 0.839v
L7220 0.120
L7260 0.128
