820-3209 No power
tipoti
hello,
there is a green light
P5V3V3_REG_EN :No voltage
PP3V42_G3H_PWRCTL: 3.4 voltage
PP3V3_S5_REG: no voltage
P5V_3V3_SUS_EN : No voltage
"PPBUS_G3H :18.49 Voltaj"
Are you sure?
Then Q7030 is bad.
BTW, use 45/60W charger for Air jobs.
Or 15V from lab PSU, if prefer...
tipoti
SORRY PPBUS_G3H :8.39 voltage
PP3V3_S5_PWRCTL : no voltage
P5VS3_EN: no voltage
PM_SLP_S4_L :No voltage
ALL_SYS_PWRGD :No voltage
tipoti
L7220: 0.440 diod mode
L7260: 0.420 diod mode
U7201
23 : 8.39 Voltage
22 : 3.3 Voltage
12 : No voltage
13 : No Voltage
29 : 1 voltage
21 : 3.3 Voltage
tipoti
No corrosion
U7941
pin1: 3.4 Voltage
pin2: 3.4 Voltage
pin3: No Voltage
pin4:
pin5: gnd
pin6: No Voltage
pin7: No Voltage
pin8: No Voltage
tipoti
I changed u7201.
SMC_PM_G2_EN = 3.4 Voltage fixed
It was a fan return. It pulls at 0.62a and after 15 seconds it turns off and on again.
I tried SMC pypass mode. The fan is spinning at full speed. It resets again after 15 seconds.
I transferred the bios from the same motherboard, still the same
