820-3330 Dead short on PPBUS
Ryanlen2
Hi. Dead short on PPBUS and PPVIN_S5_HS_COMP. No liquid. Both rails beep to ground, OV. PPVCORE_SO_CPU, 1.8OHMS. CPU does not get warm when power is applied. I have PP3V42 - 3.42V. PPCDCIN - 16.25.
Should I hunt for the short or you think dead CPU already?
Thanks
smiba
There is a fair chance the CPU is toast, if you have time for it you can try to hunt down which mosfet is shorting and replace accordingly, I've had about a 20% success rate on CPU mosfet PPBUS shorts where the CPU was not killed
Ryanlen2
Hey Smiba. Thanks for the advice. Good to know. How would you go about this? 1 volt voltage injection? Or just remove components until short is gone? Thanks man.
larossmann
The common fault on this are the CPU mosfets for PPVCORE_S0_AXG, Q7550/Q7561/Q7551 area. If you inject voltage you will kill the HD4000. Just remove them. this is ivy bridge not haswell so it won't get killed from a bad MOSFET the same way.
Of course it will beep to CPU Vcore as that is low resistance too. The correct question is: Is resistance from PPBUS to Vcore lower than the short to GND on PPBUS? That would confirm a shorted high side FET on Vcore.
Well that means there is nothing wrong with CPU FETs and you don't need to pull them for that. That is just another risk factor added now.
Inject voltage on PPBUS and see what heats up. Also check GPU Vcore for short to GND and short to PPBUS as a short there is common too.
Ryanlen2
Hey Duke. Injected up to 2 volts on PPBUS to find Q8360 is getting hot. Didnt want to do anything else until I posted. Thanks, have a good night.
Well that sucks cause it is shorted and PPBUS will have gotten to the GPU and VRAM. So expect a dead GPU, 4x dead VRAM, dead U8350, Q8360/61. Minimum that will need replacing is U8350, Q8360/61. Pull them all off and measure if there is still a short on L8360.
Ryanlen2
Hey Duke, how are ya? I pulled components you advised and I now have .100 in diode mode on L8360. PPBUS in diode .436. Thanks man, have a good day.
Probably normal as there are a few voltage dividers still present on that line. Put back all known good components.
Ryanlen2
OK. So I should assume the CPU mosfets are fine and just put them back on. or get replacements from a donor? Thanks Duke.
Ryanlen2
PPDCIN fluctuating 16.78 - 16.3V. Causing PPBUS and S rails to fluctuate as well. PP3V42 is steady. Sometimes green light on charger blinks. 0V on PPBUS with only battery.
I would say PPBUS is being pulled down by excessive current. Could be bad soldering on the replaced FETs or any other line pulling this down. Liquid?????
