820-3330 no video
jadao
I got this board witch has been messed with a little...It got a sticker with (bad video card/Bios)
Hopefully GPU has not been reflowed.
I took a look at it and here is my findings:
Initially quarter fan spin...nothing to do with charging sense resistor
L3508 completely burned...but thats not a big deal.
Wrong 2011 lcd plugged in...
Looked for knocked off component and found R8802 in another position! between R8802 pin1 and c8823 pin 1. R8802 pin 2 was not anymore connected.
Corrected all this stuff and still board with all signals power cycling...
Decided to quickly test a bios from same donnor board and actually it chimes! but still no video! Usb mouse with red light.
U8900 had very bad looking original solder joints. I decided let's touch up and reflow all the solder joint, It looks really great but nothing changed, still no video...
Tried some PRAM and checked for image but nothing.
Then I thought maybe bios should have it's original ME, so I tried a backup from the original bios and it's not detected by programmer. When I solder back bad original bios chip it has same diode mode reading than the donnour testing one...
Actually it looks like it does'nt turn on but no short!! When I remove original bios it doesn't change anything, it continue power cycling.
Is it worth spending time for this? If so how can I confirm if it's a bad ME bios chip causing that or a bad U8900?
Note: I confirmed U8900 is receiving GPUVCORE_EN 3.3V and GPUVCORE_PGOOD at 3.3V. Found also PPVCORE_S0_AXG to be 0,89V, so it looks very likely that U8900 is working properly.
Thanks for any advice
Did you test for external video.
Instead of mouse, test with OSX pendrive; if flashes, there is USB activity for sure.
"GPUVCORE_PGOOD at 3.3V"
That means GPU power supply works good.
Post some voltages at J9000; correct LCD plugged in, of course...
jadao
Yes I tested with external monitor, it doesn't work.
However I am sure there is activity,, it chimes, I can PRAM the board with external kbd.
I also see flashing activity with my usb live os hdd,
When I boot holding option key, I can see Caps Lock key light on.
Voltages on J9000:
PP3V3_SW_LCD=0V I am missing LCD_PWR_EN = 0V
Thanks
jadao
Hi 2informaticos, thanks for the dumps I downloaded it, but I can't open the compressed file, it seems broken.
Thanks
jadao
Sorry, for some reason it’s missing a line,
Since I can’t open your dump, the compressed file is reported as corrupted (maybe it’s my win xp system :), I’ve downloaded from Vinafix a bios to test. They had a 8MB version and a 4MB.
I just took a standard 8MB version.
jadao
So I tested another bios (with no warranty wether clean ME or not) and samed thing...
it chimes, it's able to PRAM but no image/backlight...
Any suggestiona? Thanks
I notice also fans doesn't ramp up due to missing trackpad, it just run quiet as if trackpad was connected??
jadao
Any suggestion about this one before I give it back? Thanks
Don't know if on this model fan ramp up progressively to maximum when trackpad is disconnected… I think it should if TS0P is located on the trackpad…
I don't know if this is most likely related to bad ME region or other additional issue...
No external video discard a problem with internal LCD.
You must have a GPU related issue.
Change U8900, just in case...
