820-3332-A
andrespi
Hello, I have a problem on this board that when connecting headphones it only sounds through one earphone,
the tests that made logical headphones other pass the same
I also tried with another audio jack port pass the same problem
preferences system balance sound is ok
I would like to know where do I start to measure where the problem is on the board
Check diode mode to ground at AUD_HP_PORT_L/R on J6701; w/ and w/o cable connected.
If all good (includin L6704/05), then change U6201.
andrespi
mode diode AUD_HP_PORT_L=0.350 measured in ohms=259 ohms. on j6701 and l6704. w/o cable connected.
mode diode AUD_HP_PORT_R=0.49 measured in ohms=9.63 Kilohms. on j6701and L6705. w/o cable connected.
with cable connected same values
on A board good condition same reference 820-3332 mode diode AUD_HP_PORT_L=0.76 AUD_HP_PORT_R=0.76 in ohms 9.7k in both
Remove L6704 and confirm if the problem is on audio codec side.
BTW, check all the points in the same manner; red probe connected to ground!
You've got one different reading.
If all readings done with red probe connected to ground, then you have a problem with that line.
"Remove L6704 and confirm if the problem is on audio codec side."
andrespi
ok thanks solved, He also has speaker problems I bought on ebay but they only worked a month, Any good quality seller where do you buy?
