820-3332 Green light no start
rlowe215
Im working on a 820-3332 and cant really understand whats going on.
With keyboard attached its starts up, but no green light and fans going full speed. Cant find ssd but boots into efi and pass.
Without keyboard I get green light but no fan spin
Measurements without keyboard
PPBUS_G3H 12.3v
PP5V_S5 5v
PP5V_S4 0v
PP3V3_S5 3.3v
PP3V3_S4 0.140v
P3v3s3_s4 3.3v
rlowe215
Measurements earlier was with board alone,
PPBUS_G3H 12.3v
SMC_ADAPTER_EN 3.3v
PM_BATLOW_L 0v
S5_PWRGD 3.3v
PM_DSW_PWRGD 3.3v
PCH_DSWVRMEN 3.22v
PM_SLP_SUS_L 3.3v
3V3_SUS 0v
JohnB8812
I suspect crap under the SMC if PPBUS is 12.3. Is SMC_RESET_L 3.3 volts? If so, reflow SMC. If no change either bad ISL or SMC likely
"PM_SLP_SUS_L 3.3v
3V3_SUS 0v"
3V3_SUS shorted to ground?
If not, post volatges for Q7802/20.
Be sure to use 85W charger!
rlowe215
3V3_SUS 0.382v in diode mode
Q7802
Pin 1 0v
2 0v
3 3.3v
4 0v
5 0v
6 3.3v
Q7820
not sure about pin positions, boardview dont show correct
1 0v
2 0v
3 3.3v
4 3.3v
5
6
7
Using PSU to power board
Does it always start with keyboard AND trackpad connected?
PM_BATLOW_L level in such case?
Can you run ASD EFI test?
rlowe215
Thats what makes me confused YES it starts all the time with keyboard but dont get green light when it starts. as soon as i disconect keyboard I get green light but no start. no charging when starts. as mentioned in start of post I can get into efi and it pass =( that why I dont understand anything about this board.
Something must have happened with the keyboard, when I plug in a brand new keyboard it dont start but get green light. So it just start with the keyboard it came in with
Remove any keyboard.
Use R5015/16 to simulate power button.
Tell us if starts then.
You didn't reply about PM_BATLOW_L level with that "bad" keyboard connected...
rlowe215
do you mean short r5016 to ground?
With bad keyboard PM_BATLOW_L at first 0 after 2 sec 3.3v and starts
changed smc and ppbus now 12.6v all other the same
"do you mean short r5016 to ground?"
Or R5015, which one you want.
In fact, solder a tiny wire to SMC_ONOFF_L and momentary touch the ground with it.
Did you start it on charger only, or battery connected too?
Do the tests without battery.
Try to start in SMC bypass, if doesn't start in normal way.
