820-3332 no green light
820-3332 no green light, im a little confused , i have ppbus g3 and pp3v42, at u6900 pin 1 (sm_bc_acok) i have 3.4v pin 5 (adaptor_sense) i have 5.15v, at pin 4 (sys_onewire) i have 3.4V but no green light ?, forgot to say no signs of any liquid damage anyway
ok thats wierd, the magsafe shows a green light on another board , but changed i anyway for a new one and guess what i have 2.9v at adaptor sense, but still no green light ,the other voltages are as before
Hi , voltage at PPBUS_G3H is 11.96v , sorry what i meant about the dc in board was it seamed to work worked in another board
Hi, no the battery is not connected , the board is out of the laptop and i dont get any light at all. If 11.96V is low what should the voltage there
JohnB8812
If you don’t get a light...using known good MagSafe board? PP3v42 present? PPBUS should be 12.56 volts which makes the SMC suspect.
Hi thanks , yes dc in board ive tried 3 new ones , will try changing the smc, does the smc have to be from an 820-3332 or could i use one from a similar board ?
Hi yes ACOK is 3.2V at pin 14 u7000, dc in fuse is 20v , ppbus_g3h at fuse f7040 / f7041 has now changed to 5.3v which was 11.96v
Hi , yes ACOK is 3.2v at pin 14 u7000, dc in fuse f6905 is 20v and ppbus at f7040 / f7041 which was 11.9v has now dropped to 5.3v ?
looks like isl6259 went bad , now have green light , but now have 12.26V at ppbus f7040 / f7041, dc in fuse is still 20v, is 12.56v at ppbus now pointing to smc ??
larossmann
12.26v at PPBUS_G3H is too low. When the SMC communicates with the ISL6259 PPBUS_G3H will be 12.56v. Is SMC_RESET_L 3.4v?
