820-3435 keyboard trackpad only work in OS AND FAN RUNS IN FULL
MOMOH
Hello guys , please I need your help, have got a MacBook Air 11inch whose keyboard/trackpad will only work in OS and the keyboard fan runs in full speed.
HISTORY : initially the machine would intermittently switch off , so I had to replace the SMC and it works except the issue above, so I thought maybe the SMC was not good so installed another one , but still the same.
Inspect USB_TPAD_P/N lines for corrosion.
Post U4810 voltages before login to OSX; remove internal SSD to avoid system booting.
If also fan runs always high, makes me thinking both problems could be generated by trackpad board/flex.
Start trying known good ones.
You can run corresponding ASD EFI version and see what error pops up.
MOMOH
On U4810
PIN 1 = 3.3V
PIN 2 = 0V
PIN 3 = 0V
PIN 4 = 0V
PIN 5 = 3.3V
PIN 6 = 0V
PIN 7 = 0V
PIN 8 = 3.3V
TPAD_SPI_IF_EN_CONN circles between 0v,1v,2v when the keyboard is not connected , but straight 0V after connecting the keyboard
Missing TPAD_USB_IF_EN signal at U4810; check diode mode to ground.
I hope you measured with trackpad connected.
Check R1619.
If good, then is PCH issue.
Please, do NOT quote an entire post visible few centimeters above.
Maintain forum aesthetic...
