I kinda figured as much. Going to do what I can these people who sent it to us get a sweet deal (aka we don't make shit) so spending more than an hour on their stuff is really not the best idea. Going to check tho if CPU Vcore is cycling what would that mean?
All the rails kind of fluctuate once the fan comes on. For example if the fan goes off PPBUS goes to 8.38 then once the fan comes on it stabilizes to 8.59. CPU Vcore will go all the way to zero when the fan is off then pulse as high as 3.7 volts then stabilize when the fan spins at 1.75
Termination resistors and traces are good. HOWEVER, I just found that I never get 3v42 on U1950 at ALL. Does this mean U1950 is fucked or does this mean there is something up with 3v42? I do get a steady orange light at all times
No change. Every single trace on the BIOS connects to its corresponding spot. Same with resistors. They all measure in spec, and there are no obviously fucked probe points really on the entire board for that matter.
I assume you already ripped off J6100? Pull the BIOS chip and do a diode mode reading on each pin. Try another known good BIOS for testing, can be from 3435 or 3437.
Swapped ROMs and still doing it. I'm gonna call this one because don't have a lot of time left with this one. Any other ides what could cause it? Rest of board looks very clean
