820-3437 Power Issue
smiba
How are your S5 rails doing?
Voltage of PP3V3_S5, PP5V_S5, S5_PWRGD, PM_SLP_S4_L, PM_DSW_PWRGD?
So it is power cycling. The usual suspects apply again: U1950 pin 8, U1900, U6100 and termination resistors/traces to it.
iambehr
u1950 getting 3.42 volts. All termination resistors test as ok (none failed high resistance anyways) and the traces connect thru on each end.
No issues with pads / traces at u1900, chip is getting power.
I will probably replace u6100 with a known working one and see what happens.
iambehr
Changed the bios chip w/ a known good one. No change in state at all. Maybe time to throw this one in the bin?
iambehr
No Title
Here ya go. "Hi-Res"... from the crappy amscope camera. I just need to buy the canon slr adapter.
I checked and double check all of the lines back to the resistors under the CPU. 3.3v getting to all of the pins on the bios chip that need it. U1900 getting all of the proper power as well.
There are a lot more termination resistors than in those pictures. Look at schematic, 16 of them or something. Also check for corrosion on J6100.
iambehr
Checked all resistors on page 61 "SPI Bus Series Termination". J6100 always gets removed and the pads wicked cleaned. I'll recheck monday again maybe I missed one.
I think originally the only visible signs of liquid damage were at j6100.
iambehr
So to revisit.. I have two of these with the same symptoms. Checked end to end continuity of all spi termination resistors and traces.
U6100 is getting power, U1900 is getting power.
Could the clock chip go bad?
Is this a common no fix?
iambehr
Yes.
The strangest bit - I accidentally disconnected SPI_MLBROM_CS_L from SPI_CS0_L and CPU Vcore and all rails stabilize, and the fan spins up full. No display out or signs of booting at this stage - which I do not expect would happen.
I will replace the flash chip next workday to see if it is bad.
