820-3437B - Not turning on, no fan spin
mushr00m
820-3437B
Not turning on
No fan spin
All the main rails are present
The only weird stuff is
PP1V05_S0 and _SUS which are supposed to be 1.05V and both lines are 1.40V
mushr00m
Just measured on C7648 and its 1.42.
But the funny thing is that right now it made the RAM BEEPS after pluggin the cord. It didnt happen before!
You may have a problem with RAM, or CPU.
1.42V at C7648 is too high; there could be problems on U7600 area.
Check all surrounding components; pay atention to R7611/12.
mushr00m
I already replaced U7600 and the resistors are R7612 = 40K AND R7611 = 30K on the multimeter measure on another board and gave me the result to be honest. I think they are good... Should I try to reflow the RAM one more time?
1.42V is high too much there!.
Such value can only be caused by faulting components, or corrosion.
Anyway, you can try to adjust the correct voltage playing with mentioned resistors.
Someyime Apple provides a formula for output voltage, based on feedback resistors.
Check page 49 to make an idea; 3V42_G3H generation, as example.
mushr00m
Yeah I know its too high
I check all the components around U7600 and replaced U7600 twice.. Still no result
I found Q1920 missing on the board replaced and still same behavior. Not sure if without would make a difference
Not sure how to try to adjust voltage with the voltage dividers you told me. Would you replace those voltage dividers according to the results on the multimeter being barely different of the schematic?
Did you see the formula in page 49???
Q1920 related resistors are good?
Do you get VTT/REF from U7400?
BTW, any reason to quote an entire post visible few centimeters above?
Please maintain forum aesthetic...
mushr00m
Put back Q1920 and a cap that was missing now I do get back to 1.05v ON PP1V05_S0... Still no FAN SPIN and CPU gets HOT
mushr00m
This one was water damaged to be honest with you and went to another store... I am carefully inspecting it and now it doesnt appear as has more components off
I just found its missing C7570 / C7541
However I think they would not be the cause to turn on
mushr00m
Weird mannnnn
Now it turned ON..
No chime...
The system is loading however it seems to be LOADING so slow...
Still no FAN SPIN
It's taking too long loading the system. I will be waiting however already sent this message
mushr00m
It bring really slow to the password recovery screen... Tried reset SMC
Reset PRAM seems to be not working...
I think there is a sensor issue also
Glad to hear it works.
Didn't expect to solve it, being sent out from other service.
Please let feedback with the solution.
This can help other members in the future.
mushr00m
Actually it was missing a cap around U7600 and I didnt notice it at first. Then put two more caps C7540 and C7570 and tried to check USB activity as you told me and the machine was working. I got surprised also
