820-3476 fan spins for about 2 seconds then stops and repeats
No-Clean
820-3476 fan spins for about 2 seconds then stops and repeats for as long as it is connected.
This machine was liquid damaged and taken somewhere else were all they did was a ultrasonic run.
U 7100 was corroded a bit so I replaced it, but same thing still.
No-Clean
PPbus is 12.96 when the fan first starts to spin, pp3v42_g3h is a 3.42v steady even when the fan stops for a second.
12.96V w/ or w/o battery?
Check which big coils get voltage (or pulse at least) in the 2s.
First try starting in SMC bypass mode.
Next try complete NEW BIOS file; do NOT clean ME from original.
No-Clean
JohnB8812 Thanks for the tip, after checking diode mode on pins 17/18 and 27/28 pin 17 was 0.610 and not 0.140, the problem was pin 3 of R7150, to do it right I replaced R7150 after cleaning the pads well. Muchas gracias!
No-Clean
Yes working now, but I have a new issue, the battery charges really really slow, coconut battery is telling me that it is charing with 4watts, back to troubleshooting
I doubt you can measure 0.004 ohm (4 miliohm).
I suppose to be 4 ohm, which is OK.
In case 0.004 is diode mode reading, that could be wrong; aprox 8 ohm real value.
Some DMMs shows half value than ohm scale in diode mode!
Post PPBUS voltage and battery percentage reported by OSX.
No-Clean
I have to revive this post as this MacBook is charging super slow, I check what U7100 area and R7150 where I did some work but all looks well, how do I make sure sure the battery is receiving enough/proper current?
Looks like battery issue then.
Try known good one, even older; new chinese batteries are crappies.
Q7155 is ON and allows battery charging.
However, post SMC_DCIN/BMON_ISENSE levels.
ALso try PRAM reset.
