820-3476 macbook pro
Can you explain what is the problem with this board?
No video, no USB activity???
Try to start in SMC bypass mode.
"No video, no USB activity???
Try to start in SMC bypass mode."
The board is working and only missing SMC_SENSOR_PWR_EN???
JohnB8812
Ok you have way more than missing SMC_SENSOR_PWR_EN forget about that rail. Voltage on PPBUS_G3H? PPVRTC_G3H, PP5v_S5, PP3v3_S5, PP3v3_SUS, PP5v_S4 present???
You've fixed the atention in something irrelevant at this point...
"and all the rails are present"
Post the ALL then...
Thanks for your replay al these rails are present
PPBUS_G3H
PPBUS_S5_HS_COMPUTING
PPBUS_S5_HS_OTHER5V
PPBUS_S5_HS_OTHER3V
PP3V42_G3H
PPVRTC_G3H
PP5V_S5
PP5V_S4
PP3V3_S5
PP3V3_S4
PP3V3_SUS
PP3V3_S3
PP3V3_S4_TBT
PP1V05_SUS
and these rails are missing:
PP3V3_S4SW_SNS
PP1V35_S3
PP1V35_S3_CPUDDR
PPVTTDDR_S3
"8.85v"
Do you mean 8.58V???
"PP3V3_S4SW_SNS
PP1V35_S3
PP1V35_S3_CPUDDR
PPVTTDDR_S3"
You've posted other S4/3 voltages as present; so these ones should also be present.
Check for short on any of them.
An o-scope should help to catch a pulse at least, if present...
Start then to check powers and enable for all these S3 supplies which don't deliver tension.
PM_SLP_S4_L is present, but some resistors derivate this signal to enable various supplies.
When you have doubt about any sensor, try to start on SMC bypass.
As you got S4 voltages, board is starting.
Check if all coils pulse at least.
Bypass SMC reffers to a way to start the board disabling SMC sensors.
And is explained in the results of the link above mentioned.
Press power button, plugin the charger and maintain power button pressed 5-10s...
Dear Sir thanks for your replay and I apologize if I ask a silly question time by time, Please take into consideration that board repair is not what I do for living it is my hobby and I'm not learning it on other peoples machines I bought couple of defect macbook/ macbook pro ( these are not donor boards and fixable ) and I'm trying to get them fixed.
and I really do appreciate your time and effort.
And I wish you a very nice weekend ahead.
