820-3536-05 No Green Light. Works on Battery.
computer had liquid damage
works completely fine on battery but will not power on with charger, will not charge battery
I don't see any obvious corrosion points and have finished an ultrasonic on the machine.
I am at a loss of what to check. I know the PP18V5_DCIN is very low but cant find anything pulling it down.
no green/orange light
Here are some measurements i took.
pin 1 and pin 2 of j7000 pulse to 24v then drop back down to 2-3 v and orange light when testing voltage
68k resistance from pin 1 j7000
r7012 68k
r7010 101k
r7011 10k
r7020 46.9
l7095 0
r8141 95k
pp3v42 pulsing from 100mv to 3.42v only when testing
pp3v3_s5 missing
PPBUS_G3H 290mv
smc_pm_g2_en missing
r7116 3.02k
r7115 99.9k
r7112 1.01k
r7142 1.01k
r7110 59.3k
r7111 21.07k
r7105 20
r7185 467k
r7121 10
r7122 10.2
r7180 1.29k
r7181 61.4k
r7125 0
r7120 .01
Glad to be here i have already fixed a board going through previous topics.
Thank you in advance.
larossmann
I'd ask for resistance to ground on pins 1/2 of J7000, but my bet is Q7180 is bad. Do you have a donor board to swap from?
I do not have a donor board with the same q7180, but i can order the part.
Resistance from pin 1 to ground is 68k
2.63v on gate of q7010
I just pulled q7180 and inspected, there was a bit of corrosion between one of the pads on the chip and the board, i cleaned and reseated, and now it is working, is this possibly a case of heating a transistor making it temporarily work or is it possible that the corrosion was the culprit?
Turns out that was the case, as soon as the board cooled down from heating in that area, the board stopped powering.
i have a q7180 from a 820-2915 turns out it was the same component. Swapped, powers on battery is charging. This case is solved.
Thank you guys so much! i had sat this motherboard aside a couple of months ago.
