820-3787 no image external/Internal
BCN_Techs
History;
Broken display, changed it and it worked for 20 minuts. Now chime CPU is heating but GPu is cold.
Things i already tried
- changed U9300
- Reflow U9600 and U9650, No change.
J8300 pins 28-30 0V.
GPUVcore 0V
No line seems to be shorted.
No reason to measure J8300, if no GPU VCORE present.
Image MUST appear before the backlight.
Post basic voltages for U9300; pins 17, 16, 25, 38.
BCN_Techs
P1V8GPU_EN is missing ans as than all rail go after this one are missing too. I see it is generated by U9600. Reflow? Can it be take from any board or it's like SMC and must take it from same board?
BCN_Techs
PP3V3_S0GPU_FET that seems to be same line you are asking me is pulsing to 0.5 V when magsafe connected and than goes down
P.S: All measerments are made with LCD disconnected
What's the reason to measure video signals without LCD?
Post Q8090 voltages.
Check diode mode to ground at =PP3V3_S0GPU_FET.
Missing =P3V3GPU_EN?
I supposed to be present, as you said
"P1V8GPU_EN is missing"
which is next AFTER 3V3GPU...
BCN_Techs
P3V3GPU_EN is missing. In openboardview when you search for P3V3GPU_EN it mark you P3V3GPU_EN and P3V3GPU_EN_L so i measured and got 3.3.
Here is correct value:
On Q8092
Pin 3 ( P3V3GPU_EN_L) is 3.3 V
Pin 1 (P3V3GPU_EN ) is 0V
