Good evening,
I have a 820-4924-A logic board with amber and green light on the charger. The board is currently out of the MacBook,and not connected to anything besides the charger.
I measured PPBUS_G3H on the fuse F7140.
Pin1: 12.68V
Pin2: 0V
I unplugged the board, tested the fuse with diode mode; probes on pin 2 and ground => Beep. I also measured 0.1 Ohms.
Problem seems similar to what was described there : https://boards.rossmanngroup.com/threads/820-4924-a-ppsub_g3h-shorted-ground.7292/
dukefawks and aprendiz asked the resistance to ground from F7140 to L7320. Original author didnt reply.
On my board, I have 0.5ohms on pin 2 of L7320, but it decreases to 0.0 in 5-6 sec.
I have 0 ohm on pin 1 of L7320
There is no sign of corrosion, no sign of liquid, board has not been cleaned; there is still dust a bit everywhere, but almost nothing.
Nothing get hot.
How do I narrow down the cause of the problem ? And if there was no liquid, then what might have caused a short?
P.S: Was I supposed to post under the old thread, 6y old, or create a new one ?
Pin1: 12.68V
Pin2: 0V
Nothing get hot.
