820-4924 no power
Kyle93
This arrived wIth no power and no liquid damage.
PPVCC_S0_CPU_PH1 only 0.53V and pp1v05s0_ll 1.055V
Is this bad CPU or should something else be checked?
pin 1 U7200 0V
NO.
You can throw it, is a redundant protection.
The problem comes from the resistor dividers placed on its inputs; considering the corresponding power supplies are good.
CPU core doesn't drop on these boards, like in new ones.
Check U1950 pin 3 voltage.
PLT_RESET_L comes high?
Kyle93
oops those CPU voltages were from another board.
Remeasured and the following is still the same on this board but CPU voltages 0v as well
L7430 0V
L7520 0V
L7560 3.3V
L7130 12.60V
