820-4924 wont charge battery intermittent green light
Gannons3
I have an 820-4924 that was liquid damaged the computer will run both off the charger and the battery just fine. When you plug in the charger with the battery plugged in it will never give a green light. with the battery unplugged it will randomly get a green light after a few times of unplugging and re-plugging. with the battery in dc in is at 2.2 volts on the fuse. with the battery out dc in ranges from 3v to .3v then will just spike to 16.5 after the green light comes on. if the battery is connected after the green light is on the charger the battery will charge just fine till full and will stay charging unless unplugged. then after re-plugging it in it will again fail to get a green light. I have no clue where to start with this because of the seemingly complete randomness.
larossmann
PPBUS_G3H is created by Q7130 sending pulses of the charger voltage through. Some 16v, some 0v. Some 16v, some 0v. It is supposed to average out to 12.56v through L7130.
If Q7130's top transistor shorts and gets stuck, it will not switch. PPBUS_G3H will permanently be 16v. The battery does not like 16v. Sending 16v to the battery will cause it to go poof. To prevent this from happening, the system shuts down the charger when it senses the battery plugged in and being given 16v.
So,
1) What voltage is PPBUS_G3H when battery is not connected?
2) IF and only IF PPBUS_G3H is 12.56v or 12.23v, does it work with a KNOWN GOOD battery?
Gannons3
ppbus_g3h is 12.56v with battery disconnected. 12.23v connected. I believe i replaced the battery in this machine at one point about 5-6 months ago.
larossmann
My best guess there is the battery is pulling down the SMC data line or is bad. Try another battery. U7100 communicates with U5000 on the same data line it uses to communicate with the battery. If it is pulled down, U5000 will not be able to tell U7100 to up the PPBUS_G3H voltage to 12.56v from 12.23v.
larossmann
USe diode mode on the meter and measure both R5381 and R5380 with red probe on ground, black probe on pin 2 of the resistor. What do you get for each? 12.23v at any time means something going on with this data line.
Gannons3
i also should say i replaced isl6259 and now i get 12.23v on ppbus_g3h weather the battery is connected or not.
SMMRepair
Well, where was the liquid? If it was to the SMC or ISL or Q7180 (7080? can't remember on 4924) area, or was it to the battery/Q7130 area? No sense in troubleshooting the battery right now if your SMC (or U5110, etc) is visibly covered in crap, etc.
Gannons3
the board is actually 100% clean. the only visible corrosion left is around Q7630 and its barely visable
Gannons3
okay so i was getting a direct short to ground on chgr_acin. removed isl that removed the short. i replaced it with a new chip now im getting 16.5v up to r7110 then drops to 4v on the other side. diode mode gives me .530 to ground after that resistor. another bad isl?
Gannons3
getting .141 in diode mode to ground on ppbus_g3H removed f7140 to see which side the short is on, its on pin 1 side
larossmann
If R7010 is hot enough to burn you then the most likely case is that PP3V42_G3H is missing as this is part of the circuit for the PP3V42_G3H power supply. PP3V42_G3H is the first rail that must show up before PPBUS_G3H is present. So my first question would be, do you have a short to ground where D7010 is? Our focus should shift to solving a potential PP3V42_G3H issue before going back to the PPBUS_G3H issue.
.141 in diode mode is not a short on PPBUS_G3H, but rather exactly as it should be.
Gannons3
okay so i put a new isl on. Im getting 12.3v on ppbus again but im still only getting 3.2v on the coil on pp3v42 also no green light on the charger 3v on acok
