820_3115 b a1278 No power
syslan
Hello,
When it got here the first time Trackpad was not working so we inyected voltage to u5805 , Got hot , after that , the mb stopped turning on.
have this Right Now
- Green Light on
- PSU consumes 0.01A
- PP5V_S3= 0
- P5VS3_EN_L=3.42 , but P5VS3_ENTRIP=0
- 5V3V_REG_EN= 3.22 , but PP5VS5_LDO=0
- P5VP3V3_REG3=0
What could it be?
Is it possible to turn it on without u5805
Injected voltage on U5805 which pin and why???
Post diode mode to ground at 5V_S5.
If short (or low value), remove R5805, L5800 and check again.
Do you get 3V3_S5/SUS?
syslan
Thanks for the welcoming.
Injected in pin 1 to see if it strated to get hot. Which it did.
5V_S5 is not in Short . value reads 630 in diode mode.
3V3_S5/SUS = 0.36
Do NOT inject voltage without reason for the future.
Post basic voltages for U7200; pins 16, 13, 3, 8, 17, 1, 6.
syslan
Update: It turns on but no Video nor USB activity :( . Tried another Bios too and no help.
Im getting theses values.
L7510/20 = 1.12V
PLT_RESET_L=3.32V
CPU_MEM RESET_L=0.67V
mem_reset_L = 1.5V
Is it possible that CPU is bad?
syslan
all resistors are OK , But I was checking a good M.B and got
CPU_IMVP_FBA_R= 0.78 V ( TURNED ON , WORKING MACBOOK)
CPU_IMVP_FBA_R= 1.1V ( NOT WORKING MB)
Is this anything? We also got PPBUS_G3H=12,55v . I dont think this is anything to be concerd off. Im trying to find a Diagnostic Post Card , we did not have one.
VCORE drops from 1.1V to 0.78V when board really boots.
This is a basic test, to confirm CPU is running.
Be sure to test with known good BIOS.
syslan
Update:
on pin 17 of u7300
DDRVTT_EN = 0V
Therefore PPVTT_S0_DDR_LDO = 0V
so i measured these signals
PLT_RESET_L = 0V
MEMVTT_EN = 0V
MEMVTT_EN_L = 5V
ISOLATE_CPU_MEM_L = 0V
PP5V_S3_MEMRESET = 5V
PM_SLP_S3_L = 3.3V
is it possible that the problem is in the PCH? what would you recommend?
"PLT_RESET_L=3.32V
PLT_RESET_L = 0V"
What happened?
VTT appears later, after power on sequence is finished.
syslan
Sorry, it may be my mistake the first time I measured PLT_RESET_L.
But now PLT_RESET_L = 0V
VCORE is still at 1.1V
syslan
I checked u2650 and saw in the microscope that pins 2 and 3 were joined by little solder, I resold it and I have
pin 4 of U2650 / 60 = 3.32 V
pin 17 of u7300 = 3.32V
pin 3 of u7300 = 0.75V
