a-1502 led functioning
Is there any video which can give full information of the functioning of step by step signal of the led of a 1502. (820-4924). I have dim display. Replaced brightness ic. All voltages missing. If possible pls provide how this circuit works. thanks
You've focused wrong the problem.
As per posted voltages, your eDP output is not even enabled.
You cannot expect backlight, if no image first.
3V at pin 5 and 5V at pins 28-30 (J8300) must appear first; at least in the first few seconds, when machine chimes.
BTW, I was considerring you've measured voltages with internal LCD connected.
Try this BIOS, as is.
i flashed the bios with the one you send. I am getting dim display. Voltages onj8300 are as below
1- 0v 3- 5v, 4-5v, 5-2.54v , 6-2.53v, 7-2.53v, 8-0v , 9-2.53v, 10-2.51v , 28,29,30 - 5.16v
Any fault history available?
Post U8310 voltages.
Check diode mode to ground at pin 1 of J8300; w/ and w/o LCD connected.
ALso check Q7700 voltages.
u8310 vin - 3.3v on- 3.3v vout - 2.5v
pin 1 with lcd connected - 1.222ohms w/o - same
q7700 pin4 - 12.49v , pin3 - 12.59v 1,2.5,6 - 0v
Jumper why???
Change U8310.
I asked about diode mode reading, not ohm at J8300 pin 1.
Red probe connected to ground, of course.
You can't get ohm value in diode mode; do not write "ohm" after diode mode reading, nor "V".
Don't make same confusion again; that made me think you measured ohm scale, not diode.
Do you get internal image for sure?
DP_INT_HPD and LCD_PSR_EN present?
Remember to check image/backlight signals and voltages ALWAYS with internal LCD connected.
yes i am getting image. question mark blinking.
yes i measured in diode mode . forward ie: red probe ground and black on pin 1 - 1.225 is the reading . reverse ie: black is ground and red on pin 1 - infinite. This is same even in ok board.
DP_INT_HPD and LCD_PSR_EN present . I have not checked this signals. I will chk and give you update.
"EDP_BKLT_EN , EDP_PANEL_PWR , all three signals are missing
LCD_PSR_EN --- 0v"
Then is impossible to get L8300 voltage, so no image possible!
PLEASE, post accurate information.
