A1466 820-3437-B no boot
flopper
820-3437-b Board came with prior liquid damage few months ago, fixed at the time.
Customer came few days ago with not booting macbook air, i checked and noticed that there is no 5V S3 and 5v S0 also.
5v S5 present.
Was poking around and applied heat to SMC around 200c for diagnostic purpose. Mac started up, worked for 10-15 min, after cooling off same issue, so i decided to reball SMC, did it, macbook worked that evening, passed tests. In the morning i came and before calling customer decided to check it, and it is not coming on with same symptoms.
So i reballed SMC again thinking i did not good job on reballin. Same thing happened, worked same day, next day does not boot with same symptoms.
What could be the issue?
Many thanks in advance.
Do you get amber light and steady 3V3_S5/SUS?
Which is the exact PPBUS_G3H voltage?
Can you tell us where was the liquid spilled first time?
flopper
Amber light - yes
G3H - 8.49v
3V42_G3H - 3.38v
3V3_S5 3.29v Steady
3V3_SUS - 3.29v Steady
Looks like prior liquid damage was around backlight and some caps on 3v42_G3H
Check PM_BATLOW_L, PM_PWRBTN_L, PM_RSMRST_L, PM_DSWPWRGD, PCH_DSWVRMEN.
Trigger SMC_ONOFF_L amd check for drop pulse at PM_PWRBTN_L at same time.
flopper
PM_BATLOW_L 3.26v
PM_PWRBTN_L 3.35v
PM_RSMRST_L 2.98v
PM_DSW_PWRGD 3.35v
PCH_DSWVRMEN 2.46v
"Trigger SMC_ONOFF_L" never did this, can you explain? Sorry for lack of knowledge.
I have to short SMC_ONOFF_L to ground and measure voltage drop on PM_PWRBTN?
flopper
PM_SLP_S0_L goes from 0.03v to 1.4v for split second
PM_SLP_S3_L from 0.00v to 0.70v
PM_SLP_S4_L goes from 3.3v to 0v
PM_SLP_S5_L stays at 3.29v
"PM_SLP_S4_L goes from 3.3v to 0v"
Should pulse high from 0V...
Looks like all pulse, then check for pulse on all big coils; S3 and S0 voltages.
flopper
i double checked, was measuring wrong resistor.
PM_SLP_S4_L goes from 0v to 1.47v
I checked at L7520 - no pulse
L7630 - no pulse
flopper
on L7320 highest peak is 0.32v
on L7310 highest peak is 0.31v
SYS_PWROK_R is 0v does not pulse if trigger SMC_ONOFF_L
PM_S0_PGOOD is 0v does pulse if trigger SMC_ONOFF_L from 0v to 1.38v highest
"at pin 3 there is 0v even if i short pin 5&6."
Check at the time you trigger SMC_ONOFF_L.
You mix the things and make dificil to follow you; we need accurated infor.
In other post you said to get pulse at pin 7/U1950.
"PM_S0_PGOOD is 0v does pulse if trigger SMC_ONOFF_L from 0v to 1.38v highest"
It cannot pulse, if pin 2 doesn't pulse too.
