A1502 820-4924-A no power
hgoncalves
I have an A1502 820-4924-A that has green light, but no fanspin and no power.
PP5V_S4 and PP3V3_S4 are missing.
PM_SLP_S4_L is missing and R1461 is OK
PM_BATLOW_L = 3.3V
SMC_ONOFF_L = 3.4V
PCH_INTRUDER_L = 2,7V
PCH_INTVRMEN=3.1V
PCH_SRTCRST_L= 3.3V
RTC_RESET_L=3.3V
Can you help?
Check the same for PM_SLP_S3_L and all big coils.
Just in case, try starting in SMC bypass mode.
Be sure to have original 60/85W Magsafe 2 charger.
hgoncalves
I Have a pulse on PM_SLP_S3_L but no pulse big coils when triger SMC_ONOFF_L, and on SMC bypass mode nothing happends.
With an original charger, the result is the same, no power
Trigger SMC_ONOFF_L repeatedly and check for pulse at each coil.
If no voltage pulse at big coils, then check diode mode.
Start checking L7520.
hgoncalves
No pulse on coils
L7520 = 0.420V
L7130= 0.154V
L7560 = 0.153V
L7710 = 0.901V
L3095 = 0.534V
L7430 = 0.145V
L7320 = 0.0003V
L7310 = 0.0004V
Post U7501 voltages; 23, 12, 13, 22, 29, 21.
Check for pulse at pin 4, when trigger SMC_ONOFF_L.
Use surrounding components as test points, not directly chip pins.
hgoncalves
U7501:
23=12.59V
12=3.4V
13=1.9V
22=3.3V
29=5V
21=3.4V
I think that P5VP3V3_VREF2 is low
I've got no pulse on pin 4 of U7501 when trigering SMC_ONOFF_L.
If PM_SLP_S4_L pulses, P5VS3_EN should pulse too.
If not, check R8175/79.
"I think that P5VP3V3_VREF2 is low"
VREF2 means something, don't you think?
hgoncalves
Well, i've never thinked about that, but now that you mentioned, i think that this means Reference Value. Is that correct?
hgoncalves
Tks, for the explanation about VREF.
I do have a pulse on pin 4 of U7501 when Trigering SMC_ONOFF_L. Sorry, I was trigering on the wrong place...
Then you should have pulse at L7520 too.
If not, there is a problem in U7501 5V area.
Check all resistors and traces.
hgoncalves
Sorry, the same error. Trigering oat the wrong place.
I do have a pulse on L7520.
The only one that seams to don't pulse is L3095
