A1708 820-00840 No backlight (SOLVED)
nik1981
I have an 820-00840 with no backlight. Tried multiple screens but no difference.
Took the board out and it seems that Q8400 is getting its 12.9v PPVIN on pin 4 but the hate voltage is also 12.9v on pin 3 so isn't opening.
I can't seem to figure out why pin 3 isn't dropping. The resistance between pin 4 and 3 is 80k so seems fine there.
Any help would be greatly appreciated
Any history available?
Do you get image for sure?
DP_INT_HPD goes high?
Check it with LCD connected!
At least check for image on external monitor.
nik1981
Hi 2informaticos, Thank you for the quick reply. I just sorted it thankfully.
It tested as low ohms on PPVOUT_S0_LCDBKLT so I decided to inject 5v into that line and have a look on FLIR
The issue was with capacitor C8470 shorting.
Replaced and now works fine.
I was having an off day obviously for not just doing this sooner.
Thanks again
