I found out that the board has got a little liquid damage under U9080, and u9080 is broken, i desoldered it from the board and the short is gone, and i have 19V.
I replaced it with another one from a donor board, but when i soldered it on the board, the short came back.
I see that the pins on the board are in a bad situation, and i am not sure if i order a new u9080 and replace it if it going to work, is there any other way to recover the data from the board now?
I mean can i recover the data with out soldering U9080 back?
BTW, it seems that u9080 gives power to the nands on the board.
I tested to connect the board to adapter with out the u9080, the area around u9080 get warm. And PP2V5_NAND_SSD0 and, PP1V8_SSD0 is shorted to the ground.
I,m wondering if the NANAs are dead by now or not! any way i can test the if the NANDs are dead or not,?
