A2251 820-01949 Stuck at 5V after water damage
wtw0987
I have a board that got a tiny bit of water damage through the air vent on the bottom of the laptop. The laptop was charging when the damage occurred and was at 1% and will not turn back on.
When plugging in an ampmeter after unplugging the battery, the reading starts at 0.087A and slowly goes down to 0.056-0.063A at about 5.14V.
PPBUS_G3H = 12.33V
PP3V3_G3H_RTC = 3.34V
I cleaned the board up with a ton of isopropyl alcohol and also reflowed the U3100_X CD3217 chip but I still have the same issue on all 4 ports. This behavior was occurring before the reflow as well. I also noticed that P3v3_S5 was at 0.01mV but I'm not sure if that is relevant yet or not.
Any help is appreciated!
0.084 is really bad; probably dead SSD.
You can remove U9080 and test again.
If still low, then dead SSD for sure.
Injecting voltage there probably doesn't heat anything.
However, a good thermal camera can help you to detect the culprit.
You may need to inject 3V and wait some time.
I recommend to start with just 1V anyway.
wtw0987
0.13P2V5_SW2_TPS62180_SSD0
0.133PP2V5_NAND_SSD0
0.177PP3V3_G3H_RTC_REG_R
0.456PPBUS_G3H
0.27P3V3_S5
0.377P3V3G3HRTC_PHASE1
0.383P3V3G3HRTC_PHASE2
0.347PVCCQ_LX0
0.365PP0V9_SSD0
0.399PP1V8_SLPS2R
0.082PP0V9_SLPDDR
0.254PP1V1_SLPS2R
Got these values after doing a quick refresher on diode mode (first time if you can't tell haha) Most of these values line up with the reference table aside from those top 3 values. Will take a look at U9080 like you mentioned as well.
wtw0987
Removed U9080 and got these values for the 3 outliers
0.373P2V5_SW2_TPS62180_SSD0
0.373PP2V5_NAND_SSD0
0.371PP3V3_G3H_RTC_REG_R
The PP3V3_G3H_RTC_REG_R value lines up with the reference sheet but the other two are still a tad off as the reference sheet has those both around 0.425 I noticed the enable pin on the SSD was not getting any voltage when the board was powered, could this be part of the issue?
The last readings are not so bad.
Check voltage on the small coils surrounding U7800.
Do you get all G3S voltages?
wtw0987
0.7vPPVDDCPU_AWAKE
1.1vPP1V1_SLPS2R
0.87vPP0V9_SLPDDR
1.8vPP1V8_SLPS2R
0.82vP0V82_SLPDDR
0vPPVNN_PCH_EXT
0vPVCCPCOREPRIM_SW0
0.8vPPVDDCPUSRAM_AWAKE
0vP1VPRIM_SW0
0vPP1P05_PCH_EXT
0vPP1V1_S3_REG_R
0vPP1V1_PHASE
0vPP1V8_G3S
0vPP3V3_G3S
0.005vPP5V_G3S
Here is all the info I could get from that. I haven't put U9080 back on the board yet either if that means anything.
wtw0987
PPBUS_G3H 0.458
L9080 0.003
I'm assuming that the SSD is dead? Could also be cause of a bad rework job I'm not the most experienced with air reflow.
wtw0987
expectedactual
PPBUS_G3H_SSD00.510.435
P2V5_SW2_TPS62180_SSD00.4250.346
SSD0_TPS62180_FB1.4130.351
SSD0_TPS62180_SS0.538.0L
SSD0_VR_P2V5_EN_R0.640.741
SSD0_CR_P2V5_PGOOD0.5650.577
This is what I'm getting with U9080 off the board on the pads.
Are these readings on the board, or U9080 pads?
If are from the board, then replace U9080.
If the short remains on the board, then dead SSD.
BTW, I asked you to check directly on U9080 pads (not on the board); not sure what you really did.
wtw0987
Ah I see sorry wording was terrible there, the readings above are from the logic board without U9080 onboard, here are the readings from the U9080 pads directly from the backside of U9080
PPBUS_G3H_SSD00.584-0.6 on all pads
P2V5_SW2_TPS62180_SSD00.517
SSD0_TPS62180_FB1.38
SSD0_TPS62180_SS0.554
SSD0_VR_P2V5_EN_R0.643
SSD0_CR_P2V5_PGOOD0.694
wtw0987
I put U9080 back on the board after seeing the readings from above and I think it is functional. Here are the readings I got on the logic board with U9080 back on it
expectedactual
PPBUS_G3H_SSD00.510.378
P2V5_SW2_TPS62180_SSD00.4250.378
SSD0_TPS62180_FB1.4131.383
SSD0_TPS62180_SS0.5380.553
SSD0_VR_P2V5_EN_R0.640.64
SSD0_CR_P2V5_PGOOD0.5650.58
PP2V5_NAND_SSD00.4250.378
Current draw is up to 0.44 amps but I'm still sitting at 5V when the board is powered.
wtw0987
GS3 voltages were all still at 0. PP2V5 is getting 3.67V and I also noticed that PPBUS_G3H is now at 4.95V instead of 12V as it was before, U9080 is feeling a bit hot as well but I'm not getting anything weird when measuring the pads for it in diode mode so I'm not sure if there is a short on it or not.
wtw0987
Gotcha, ordered one and will update once I get it and place it on the board. Thank you for the help, it is truly appreciated. This is my first ever repair as a fun side-project.
wtw0987
Recieved the new part, reflowed all of the caps and resistors surrounding U9080 as well for good measure. These are the new values.
expectedactual
PPBUS_G3H_SSD00.510.44
P2V5_SW2_TPS62180_SSD00.4250.348
SSD0_TPS62180_FB1.4131.325
SSD0_TPS62180_SS0.538.545
SSD0_VR_P2V5_EN_R0.64.612
SSD0_CR_P2V5_PGOOD0.565.565
PP2V5_NAND_SSD00.4250.346
Still getting 5.12V and sits around 0.18A Not feeling any heat anywhere or getting anything crazy on my thermal camera.
