A2337 second display
klinenator
Hi, i have an a2337 logic board. When i plug it in to power and use a usb-c to hdmi adapter it shows the extended display on my monitor. The cursor shows up and i can move it around but i cant see the main display no matter what i do.
Is there any way to get the main display on an external monitor with just the logic board?
klinenator
Hi thanks, currently the only thing hooked up to the logic board is the usb-c board with power on one input and on the other an adapter with hdmi keyboard and mouse
I have openboardviewer and the 820-02016.bvr Is it possible to short lid_open to ground or something?
klinenator
Sorry i didnt mention before i dont have anything but the logic board and the usb-c board
Here is an image of what i see
If you get image, lid signal should be good.
UR200 is in charge with lid sensors detection.
It should have high level (close to 1.8V) on all inputs and output.
klinenator
Im having a hard time finding test pads in openboardview when i click on a test pad for example TP1569 it doesnt show it as connected to anything
You can tie together pins 3 & 4 of UR200.
Or use any pin of RR203.
Removing RR200/1 should have same effect.
But leaving UR200 inputs floating on air is not the best idea; should force them to ground.
