A2442 820-02098 not charging
hgoncalves
I have an A2442 820-02098 that isn't charging; it doesn't even recognize that the charger is plugged in, saying that it is always on battery. It doesn't charge on any port (USB or magsafe).
Already tried with an original proper charger in all ports.
PPDCIN_AON = 0V and 0.538 on diode reading.
PPVBAT_AON_CHGR_REG = 11V.
PPBUS_AON = 11V
I can't see any damages on the board, and the client said it stoped charging without reason.
I don't know where to begin.
Can you help?
hgoncalves
Hi.
No, It showed 19V in all ports, but now, after I've it disabled it, and on the bench, it's only showing 5V on the USBC ports.
PP3V3_S2 = 0V and 0.450 in diode reading
PP1V8_S2 = 0V and 0.258 on diode reading
PP3V3_UPC2_LDO = 3.4V
FG200 = 0V, when conected to UG400.
With the IR camera, UG400 seams to be hot, even when coinecting on other USBC ports.
Is it possible to replace just this CD3217B12, for one from China or do I need to replace all of them?
Can you help?
hgoncalves
Hi.
I've replaced the burnt CD3217 (UG400).
Now I have 20V again, however the Mac isn't charging. It says that s always on battery.
Strangely, I left it overnight connected to the AC adapter, and in the next morning it was 100% charged, even saying the it was in battery and not recognizing the charger.
Any idea about what should I do?
Can anyone help?
What shows the USB-C meter?
You should be able to detect if battery is charging.
Does it turn on with charger alone (no battery)?
hgoncalves
Hi.
It's not charging. In ampmeter I have 20V but 0.03A (but it charged overnight, even with this values when i shutit down. maybe it started working by it self and then stoped again in the night).
Without the battery connected it doesn't power on.
Right now, after disconnecting the battery to check if it powers on w/o battery, it only has 4.83V and 0.91A on ampmeter, even with the battey connected. However, it powers on.
hgoncalves
Hi.
Yes, I've tested with an original magsafe 3 charger, and got the same result.
I've left it again overnight on charger (with only 4.83V and 0.91A on ampmeter), and on the next morning it was 100% charged, even saying the it was not charging (on battery).
Any help on how to proceed next?
hgoncalves
Hi. Yes I did,
I've bought the all 4 CD3217 for the board model, but I've only replaced UG400 because it was the only one that was shorted (heating in IR cam). Now it isn't hot and all measurements seams right.
hgoncalves
Hi.
U5200:
P_IN = 5.11V
AUX_DET =1.33V
SMC_RST_IN = 0V
VDDA = 5.089V
VDDP = 5.082V
EN_MVR = 5.086V
AUX_OK = 1.756
AMON = 0007V
BMON = 0V
Good values; the charger is correctly recognized by U5200.
Checked without battery connected?
Still doesn't turn on with charger alone?
Test with 96/140W and correct e-marked cable.
hgoncalves
Hi.
Yes, I've checked without the battery connected (board on bench alone), and already tried with an original 140W charger and magsafe 3 cable.
hgoncalves
Hi.
I can't get in DFU mode. Might it be because some bad CD3217 (usb port)?
How can I force DFU in this model?
