A2485 820-02382-A no image
hgoncalves
Hi.
I have an A2485 820-02382-A that has no image / BL (not sure). It has image on external monitor, but I can't see any image on the internal display (not even a dark one).
I don't have any other known good display to test.
How can I be sure if the problem is on the motherboard or in the display?
Can you help?
Tks.
hgoncalves
Hi.
Client said it was working and it stoped showing image.
I've checked PVOUT_LUXE_XW, and I've got 11.850V there, and I think it's to short.
I guess this is the BL output, correct?
Strange to have steady 11.85V
That means enabled, but not boosting
LPDP_INT_HPD is high for sure?
Inspect UP800 and QP800-3 areas for corrosion.
hgoncalves
I'm not sure if LPDP_INT_HPD is high. How can I measured it with without disconnecting JP600?
UP800 and QP800-3 areas seams OK, without any corrosion.
Seems good.
If backlight is enabled, the problem may be around UP800.
Check all adjacent resistors.
The best option is to test with known good screen.
