conected with WiFi but no Internet
Dozer
Hello, I have a problem I dont know what could that be.
I replaced a mainboard from a macbook air, everything is working well, only internet is aproblem.
I can see the WiFi names, I can conect to WiFi
I see my IP, DNS all isok, but safari dont let me in the internet. the same external drive is working perfect on another macbook with the same network
I replaced the wifi card but same problem. did anybody had a probplem in this way already?
please help Im going crazy on this
Dozer
yes. and he set automaticly the time over internet.
firewall is off. same hdd on other macbook is all ok
Dozer
IP4 is configured DHCP, just i toke a look and the ip and mask is a random, after click renew DCHP lease it got the "right" ip and mask. but all still the same no internet in any explorer, nothing in dropbox
Dozer
oh, good idea. that is working proper good. so i guess a bad wifi antena conector. I will try to solder the antenna directly to the wifi card
Probably end pipe screw fucked the antenna cable.
I never put back that screw again; passed to me one time...
Dozer
thanks so much for your quick help. thats it! under microscope I found what you thought. end pipe screw damaged wifi cable. I hate this screw too and I am all the time carefull, but now I am srewed as well. in futer I dont will put back that screw as well. thanks.
[SOLVED]
