[help] 820-00840 “seems to boot”
phantom
i don’t know the history of this board…I’m pretty sure that u3900 was touched/changed (i don’t know why)
Motherboard boot with “no disk error.”
Tried another disk, same error!
It can’t see usb bootable from both usb
USB stick light stay on fixed
As soon as i try to boot in Recovery and write the password, it hangs, and then reboot
phantom
I’m not able to flash
820-00840 8hv22 medusa clean ME + pram.bin
I have this error
No problem flashing my dump
You dind't say to have Medusa.
In such case, no need to remove BIOS chip.
Connect Medusa and use its Clean ME function; over your backup.
phantom
I have not medusa! I have downloaded your rar, and There are 2 bin inside
I have used the one with the name
phantom
I’m 100% sure that they have changed usb ports….because i have found t2 shield resoldered…..so I Think there must be an hardware problem….but i have not diode mode readings for usb port
richilg1
No T2 on this board, do you mean the shield for the Intel thunderbolt controller? If that chip has issues, that would explain USB inputs not working. You need thunderbolt working for using almost everything USB C, except charging
