SanDiegoHB
hi all, thanks in advance for your faithful help, it's much appreciated
suggestions for easiest way to solder this part? it has 4 large grounds on the corners.
here's my idea: pre-solder all the pads with low melt ~361F, heat underneath with the highest heat possible without damaging anything (in this case there's no plastic nearby underneath so I'm thinking about 650F?), at the same time press down on the connector while using hot air from above (do you think the required temperature at that point would be low enough to not melt the connector plastic?)
