imac A1312 2009 27inch, core2duo backlight goes away
ielectron
serial number W894716C5PM
I did not open this imac yet, the issue is the backlight, randomly goes away, then i press the power button to put into sleep, then press it again to wake it and the backlight comes back. When its off, like after 10-60 minutes, with a flashlight i can see the picture and mouse moving.
The backlight always comes back with this sleep-wake method, or by unplugging the power cable and start it again. Same if i boot from ext. hdd.
Fixed only few imacs before, what is the more likely to be faulty? screen? board backlight IC?
I dont have another imac screen to test with.
Bad soldering on the LED strips in the LCD. Need to totally pull apart the LCD, take out the 2 LED strips and reflow each LED and the connectors.
Gurmon
Just to add, this is a real mission separating the display first time. can be done, but high chance it goes wrong first time.
Alan.L
is this an common fault on all older iMacs and Apple Cinema Display (non-thunderbolt), like the one i just repaired?
i want to fix another one lol to improve my expertise..
Alan.L
its actually very simple, remove the tape and any screws out of the way. then use a Metal Spudger to pry the frame out.
the screen cost too much.
I'm sure there are a few videos on youtube as these LCDs also have the common clouding issues by dust getting in the backlight diffuser. It is 100% the LCD and very very common on all 27" LCDs.
The easy way out here is to get a bad/cracked LCD and just swap over your good "glas" part.
