Imac with MCP79MXD-B2
MDY
Have imac with MCP79MXD-B2
Has video problems. Worth to replace or there are not new chips?
MDY
Wow, thank you. I was going to replace MCP
Bad panel or bad board on panel. I know some panel have boards and I can replace them.
Since when were 27" imacs made in 2008?
Als LM270WQ1 are the same 2009-2011. Only thing different is the SYNC cable for the inverter. You can swap the control board on the LCD or make up a new cable.
