MeTech Turkey
Hello everyone I have an iphone 11 and we have swapped the board as we had probolems with restoring the device. Was always getting error 9 .After swapping the board device restored successfully but now having problem with no Imei on the phone. Checked the values aroudn BB and BBPmu on diode mode everything seems well. And I just realised that after restoring on idevice details page of 3utools wifi serial number and wifi module also missing and the device restarts randomly. I will share the panic logs on the end of the message. And also I realised that I have to read aroudn 350-390 on pad 243 which is located next to PA_HB_K and it is connected to this IC. I have tried the remove the ic then I get OL which ic normal. But I have tried 3 different ICs but always same result. Does this effect the baseband and wifi data on restore?
Here is the panic log also:
panic(cpu 1 caller 0xfffffff015c77618): userspace watchdog timeout: no successful checkins from thermalmonitord
service returned not alive with context : is_alive_func returned unhealthy : current 3bffffffffffc, mask 1ffffffffffff, expected 1ffffffffffff. SD: 0 BC: 1 RC: -1 BS: 2, Missing sensor(s): TG0B TG0V mic2
service: backboardd, total successful checkins in 200 seconds: 19, last successful checkin: 0 seconds ago
service: SpringBoard, total successful checkins in 169 seconds: 17, last successful checkin: 0 seconds ago
service: mediaserverd, total successful checkins in 200 seconds: 18, last successful checkin: 0 seconds ago
service: logd, total successful checkins in 200 seconds: 19, last successful checkin: 0 seconds ago
service: thermalmonitord, no successful checkins in 200 seconds
service: runningboardd, total successful checkins in 200 seconds: 19, last successful checkin: 0 seconds ago
service: wifid, total successful checkins in 200 seconds: 19, last successful checkin: 0 seconds ago
service: configd, total successful checkins in 200 seconds: 18, last successfu
Debugger message: panic
Memory ID: 0x1
OS release type: User
OS version: 20B101
Kernel version: Darwin Kernel Version 22.1.0: Thu Oct 6 19:32:38 PDT 2022; root:xnu-8792.42.7~1/RELEASE_ARM64_T8030
Fileset Kernelcache UUID: 59C2F1BFB41BDBE006709A8AB5D82681
Kernel UUID: 17EB6472-1780-3881-B28A-6CCF175F7F46
Boot session UUID: 728721B7-F811-4001-B262-54E402EBCFAA
iBoot version: iBoot-8419.40.112
secure boot?: YES
roots installed: 0
Paniclog version: 14
KernelCache slide: 0x000000000d610000
KernelCache base: 0xfffffff014614000
Kernel slide: 0x000000000e28c000
Kernel text base: 0xfffffff015290000
Kernel text exec slide: 0x000000000e344000
Kernel text exec base: 0xfffffff015348000
mach_absolute_time: 0x1208f2dd1
Epoch Time: sec usec
Boot : 0x00001988 0x000d412c
Sleep : 0x00000000 0x00000000
Wake : 0x00000000 0x00000000
Calendar: 0x00001a43 0x000e0333
Zone info:
Zone map: 0xffffffe11ac14000 - 0xffffffe71ac14000
. VM : 0xffffffe11ac14000 - 0xffffffe201278000
. RO : 0xffffffe201278000 - 0xffffffe24df44000
. GEN0 : 0xffffffe24df44000 - 0xffffffe3345a8000
. GEN1 : 0xffffffe3345a8000 - 0xffffffe41ac0c000
. GEN2 : 0xffffffe41ac0c000 - 0xffffffe501274000
. GEN3 : 0xffffffe501274000 - 0xffffffe5e78dc000
. DATA : 0xffffffe5e78dc000 - 0xffffffe71ac14000
Metadata: 0xffffffe71ac24000 - 0xffffffe71c424000
Bitmaps : 0xffffffe71c424000 - 0xffffffe71da04000
CORE 0 recently retired instr at 0xfffffff0154ce85c
CORE 1 recently retired instr at 0xfffffff0154cd308
CORE 2 recently retired instr at 0xfffffff0154ce85c
CORE 3 recently retired instr at 0xfffffff0154ce85c
CORE 4 recently retired instr at 0xfffffff0154ce85c
CORE 5 recently retired instr at 0xfffffff0154ce85c
TPIDRx_ELy = {1: 0xffffffe41b796bd8 0: 0x0000000000000001 0ro: 0x000000016f10b0e0 }
CORE 0: PC=0x000000020acbeca0, LR=0x00000001cc0f3aac, FP=0x000000016de96500
CORE 1 is the one that panicked. Check the full backtrace for details.
CORE 2: PC=0x00000001cc0f281c, LR=0x00000001cc0f59fc, FP=0x000000016fb79fd0
CORE 3: PC=0xfffffff0153c29b4, LR=0xfffffff0153c29b4, FP=0xffffffee8aaf7f00
CORE 4: PC=0xfffffff0153c29b4, LR=0xfffffff0153c29b4, FP=0xffffffee8a863f00
CORE 5: PC=0xfffffff0153c29b4, LR=0xfffffff0153c29b4, FP=0xffffffe8a5637f00
Compressor Info: 0% of compressed pages limit (OK) and 0% of segments limit (OK) with 0 swapfiles and OK swap space
Total cpu_usage: 41404168
Thread task pri cpu_usage
0xffffffe41b796bd8 watchdogd 97 0
0xffffffe41b75b618 backboardd 63 0
0xffffffe41bf850f8 launchd 37 43
0xffffffe41afd7290 kernel_task 0 5839853
0xffffffe41afd5e68 kernel_task 0 0
Panicked task 0xffffffe41a0775c8: 292 pages, 3 threads: pid 57: watchdogd
Panicked thread: 0xffffffe41b796bd8, backtrace: 0xffffffee8a8270d0, tid: 1506
lr: 0xfffffff01538eebc fp: 0xffffffee8a827110
lr: 0xfffffff01538ec90 fp: 0xffffffee8a827180
lr: 0xfffffff0154d49dc fp: 0xffffffee8a8271a0
lr: 0xfffffff0154c7968 fp: 0xffffffee8a827210
lr: 0xfffffff0154c6364 fp: 0xffffffee8a8272d0
lr: 0xfffffff01534f610 fp: 0xffffffee8a8272e0
lr: 0xfffffff01538e6a4 fp: 0xffffffee8a827690
lr: 0xfffffff015aa644c fp: 0xffffffee8a8276b0
lr: 0xfffffff015c77618 fp: 0xffffffee8a8276d0
lr: 0xfffffff015c76ea0 fp: 0xffffffee8a8276f0
lr: 0xfffffff015c75d54 fp: 0xffffffee8a827810
lr: 0xfffffff015a1ef38 fp: 0xffffffee8a827840
lr: 0xfffffff015a1f220 fp: 0xffffffee8a8279d0
lr: 0xfffffff015498a6c fp: 0xffffffee8a827af0
lr: 0xfffffff015394e80 fp: 0xffffffee8a827b90
lr: 0xfffffff015367fb4 fp: 0xffffffee8a827bf0
lr: 0xfffffff015380ca4 fp: 0xffffffee8a827c90
lr: 0xfffffff01538111c fp: 0xffffffee8a827d80
lr: 0xfffffff0154bc6cc fp: 0xffffffee8a827e50
lr: 0xfffffff0154c66ac fp: 0xffffffee8a827f10
lr: 0xfffffff01534f610 fp: 0xffffffee8a827f20
Kernel Extensions in backtrace:
com.apple.driver.AppleARMWatchdogTimer(1.0)[E87C0F43-E180-33BE-B856-D3276A92C0F8]@0xfffffff015c73250->0xfffffff015c77617
dependency: com.apple.driver.AppleARMPlatform(1.0.2)[B5937EC7-0D89-3C0B-92EB-42309DD87933]@0xfffffff015c26020->0xfffffff015c7324f
last started kext at 555924702: com.apple.driver.AppleUSBEthernetDevice 7.0 (addr 0xfffffff014a6caa0, size 4658)
Memory ID: 0x1
OS version: 20B101
secure boot?: YES
roots installed: 0
Zone info:
